billygoat's avatar
billygoat
Adding Powerline WiFi access point to existing Powerline AV 200
Is it true that I cannot buy a single access point - I have to buy the adapter/access point pair? If that's the case I guess I'll have to get the PWL1000 and add the AV200 access point to the system...
  • michaelkenward's avatar
    michaelkenward
    Jul 13, 2017
    Your wifi devices could end up being confused and not knowing which network to join, especially when you move from place to place. I always use different names.
