NufGriff
Feb 24, 2018Aspirant
Adding wifi facility yo PL 1000 system
A Power line 1000 was added by Virgin Media to provide link from Virgin Hub 3 to the new V 6 TV Box system which is around 40 feet from Hub 3 Modem/Router. But no wifi. Hope to add a unit to the ...
- Feb 25, 2018
NufGriff wrote:
... it would be useful to be able to access wifi in the TV (connected via PL 1000/LAN) room for our mobile 'phones etc.It seems that the purchase of a PLW 1000 would make the present PL1000 system redundant...
You've got it. The PLW1000 suggested by clithes would deliver wifi into the TV room as well as a wired link to the TV.
The "remote" end of the PLW1000 is an Access Point for wifi and a LAN socket for the TV. It can do both at the same time. A perfect choice for your needs.
clithes
Feb 25, 2018Prodigy
A PLW1000 will add wifi for you, as well as provide a wired connection
https://www.netgear.com/support/product/PLW1000.aspx
Hope this helps
michaelkenward
Feb 25, 2018Guru - Experienced User
That's good advice. It is how I do things. I chip in only to add this link to the page that tells you how to do add the new plugs to your existing Powerline network so that you have only one plug connected to the router:
>>> Adding a powerline adapter to an existing powerline network <<<
I will also bring you some bad news, well, maybe not that bad. You will not be able to buy a single PLW1000 plug. Netgear, and most Powerline makers, sell bundles of pairs of plugs. So you may end up with a spare plug. (You need only one connected to your router if you follow the stiff in the link above.) Perhaps you have something else that could use that.
