NufGriff
Feb 24, 2018Aspirant
Adding wifi facility yo PL 1000 system
A Power line 1000 was added by Virgin Media to provide link from Virgin Hub 3 to the new V 6 TV Box system which is around 40 feet from Hub 3 Modem/Router. But no wifi. Hope to add a unit to the ...
- Feb 25, 2018
NufGriff wrote:
... it would be useful to be able to access wifi in the TV (connected via PL 1000/LAN) room for our mobile 'phones etc.It seems that the purchase of a PLW 1000 would make the present PL1000 system redundant...
You've got it. The PLW1000 suggested by clithes would deliver wifi into the TV room as well as a wired link to the TV.
The "remote" end of the PLW1000 is an Access Point for wifi and a LAN socket for the TV. It can do both at the same time. A perfect choice for your needs.
NufGriff
Feb 25, 2018Aspirant
Thanks Michael. If I've correctly understood what you said, you'll soon be getting that most important birthday card from the Queen.
Jokes aside, thank you for your help, things are becoming much clearer and a swap would be good as it would be useful to be able to access wifi in the TV (connected via PL 1000/LAN) room for our mobile 'phones etc.
It seems that the purchase of a PLW 1000 would make the present PL1000 system redundant, or, if just using the wifi/LAN end of the PLW 1000 would make the input end redundant. Hope to have a word with Virgin tomorrow.
I usually get there in the end particularly with the help of members of relevant communities, like your good selves, for which I'm always very gratefull
warmest regards
graham davies
michaelkenward
Feb 25, 2018Guru - Experienced User
