MickSpence
Jan 02, 2016Aspirant
Additional Powerline Adapters can't access internet.
Hi, I have recently purchased a new Netgear router (the R7000-100UK), turned my Virgin Media Superhub into modem only mode, and using two fairly old Netgear powerline adapters I already owned (fo...
- Jan 13, 2016
Hi,
Changed my R7000 to Access Point mode, and took my SuperHub out of Modem only mode (but making sure the SuperHubs wireless stuff was turned off). Then made sure I didn't use any Yellow Ethernet ports when wiring up my home network,
It's all appears to be working so I'm happy that I've fixed my issue.
Thanks for all your efforts.
Mick
clithes
Jan 02, 2016Prodigy
We really need to know which models you have. HomeplugAV2 is backwards compatible with HomeplugAV, for example, but neither would work with the original Homeplug 1.0 specification (like an old HDX101 unit)
Without knowing what kit you have it's difficult to answer what might be going wrong
If your laptop is showing an IP address of 169.xx.xx.xx then it isnt getting an IP address from your network via DHCP, it is, in effect, giving itself an IP address.
MickSpence
Thanks for your prompt response.
Just checked, and the two existing power adapters are XAV5601's.
- clithesJan 02, 2016Prodigy
Ok so they are HomeplugAV compatible. What version have you just purchased?
- MickSpenceJan 02, 2016Aspirant
That cool that they are compatible.
Sorry I didn't add these product numbers in my reply, was sure I'd list this info in the original question.
The adapters I have just brought was the XAVB5221 set that includes two XAV5221 adapters.
Can you connect wirelessly to your R7000 and connect to the internet ?
My guess is your set up between the Virgin Super Hub and your R7000 is the problem. From what you've said it sounds like your powerline adapters are all 'talking' to each other.
Did you run the setup wizard on your R7000 when you connected everything ?
You need to make sure to connect the Lan cable to the WAN port (yellow port) from the powerline adapter to your R7000
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM_26Feb2015.pdf
Page 13 onwards for a diagram of what your set up should look like. Only difference you have is a couple of powerline adapters making the yellow lan cable connection in the diagram
