MickSpence
Jan 02, 2016Aspirant
Additional Powerline Adapters can't access internet.
Hi, I have recently purchased a new Netgear router (the R7000-100UK), turned my Virgin Media Superhub into modem only mode, and using two fairly old Netgear powerline adapters I already owned (fo...
- Jan 13, 2016
Hi,
Changed my R7000 to Access Point mode, and took my SuperHub out of Modem only mode (but making sure the SuperHubs wireless stuff was turned off). Then made sure I didn't use any Yellow Ethernet ports when wiring up my home network,
It's all appears to be working so I'm happy that I've fixed my issue.
Thanks for all your efforts.
Mick
MickSpence
Jan 04, 2016Aspirant
Hi,
Spoke to the network chap at work after returning from our Xmas break.
He's pretty sure the problem is that I'm trying to use the yellow ethernet cable port on my router for both WAN and LAN networks. I kind of assumed that one cable could do both. He thinks the best fix would be to move the Router to the front of the house next to the modem which might be a problem getting wireless signal to all corner of the house, or turn off the R7000 DHCP and any other services I've got switched on there and turn them back on in the SuperHub, and use the R7000 for it's wireless functionality only (while making sure I don't turn on the Superhubs wireless adapter).
Can't do this for a day or two as need to explain to family that they need to redo all their network connects etc.
Will let you know if this fixes it.
MickSpence
Jan 13, 2016Aspirant
Hi,
Mick
- clithesJan 14, 2016Prodigy
Glad you've got it all working
