Surfrat96
Jan 14, 2017Aspirant
Amazon Fire TV
I purchased the Powerline 1200. As the directions stated, I plugged one adapter with an ethernet into the router/modem. The other is for my Fire TV box which I have the other adapter into the wall wi...
netwrks
Jan 14, 2017Master
Check your TV manual set up. If the TV is connected to WIFI, then it's the TV config.
clithes
Jan 14, 2017Prodigy
On your Amazon Fire TV, go into 'Settings' then 'Network'. At the top right hand side of the screen does it say Wired (Connected) or Wireless (Connected).
If it's wireless, configure your connection to wired from here. However, I was under the impression that the Fire TV would default to wired if a LAN connection was detected.
