Surfrat96
Jan 14, 2017Aspirant
Amazon Fire TV
I purchased the Powerline 1200. As the directions stated, I plugged one adapter with an ethernet into the router/modem. The other is for my Fire TV box which I have the other adapter into the wall wi...
Surfrat96
It's not the TV. Originally I connected the HDMI directly into the TV and it showed that it was wired and everything was perfect until I tried to play the sound through the AVR and it wouldn't. Sound would only come out of the TV. I was advised to run the HDMI from the Fire TV into the HDMI in the back of the receiver, which I did and now the sound comes out through the receiver, but the connection is now wifi?
clithes
Jan 14, 2017Prodigy
and what does it say when you go into settings then network on the Fire TV? Have you tried to configure the connection?
