bgma79
Apr 01, 2018Follower
Are XAV5421 powerline adaptors compatible with PL1000-100UKS.
Are XAV5421 powerline adaptors compatible with PL1000-100UKS.? I have a pair of XAV5421 installed and wish to extend coverage with some extra adaptors. 5421 are no longer available so can I add P...
clithes
Apr 01, 2018Prodigy
Yes the PL1000 (Homeplug AV2 standard) is backwards compatible with your XAV5421, which is Homeplug AV standard. So they should work perfectly well together.
Hope this helps.
michaelkenward
Apr 02, 2018Guru - Experienced User
Indeed, but when adding new plugs to an existing network, remember this:
>>> Adding a powerline adapter to an existing powerline network <<<
