tomcat270
Feb 17, 2018Aspirant
att wireless internet
ATT wireless Internet using AV 500 to extend signal 170' to outside building on the power line want work . Any sugestions
tomcat270
Feb 18, 2018Aspirant
I am Trying to run wireless internet to a desttop computer using the netgear V 500 On the wired line going to my shop it work with a DSL line. Not working with the new wireless .
michaelkenward
Feb 18, 2018Guru - Experienced User
What is that? I can find no V 500 in Netgear's list of model numbers. Do you mean AV500 Powerline plugs? If so, what model numbers? (AV500 is an industry standard that Netgear uses for various devices.)
I'm sorry but I have no idea what you are trying to do.
Let's break it down. You have DSL Internet in one building and you want to get it somewhere else. Is that right?
You have put this question in the section about Powerline Ethernet. Does that mean that the two buildings are on the same mains circuit? Their electricity comes off just one fuse box? And you want to use Powerline Ethernet to join the two buildings?
Where does this new wifi come from? A Netgear router of some sort? What is at the receving end in the way of wifi equipment.
If these buildings are 170 feet apart, you probably won't have much luck with wifi or Powerline Ethernet. That's a long run.
Then again, I still have no idea what you are trying to do. That's why I am asking these stupid questions.
