BernardD
Jan 24, 2018Aspirant
AV 500 and PLP 1000 compatible or not compatible ?
Note : it is not possible to select the PLP1000 model in the box here above Hello, I have bought a pair of PLP1000-100FRS powerline adapters. I aleary have a powerline nerwork with three AV5...
- Feb 01, 2018
I have exchanged the CPL1000 for CPL12000.
CPL1200 works.
CPL1000 is definitly not backward compatible.
michaelkenward
Jan 29, 2018Guru - Experienced User
Your attachment does not show any plug with a connection to your router.
BernardD
Feb 01, 2018Aspirant
CPL1200 works.
- michaelkenwardFeb 01, 2018Guru - Experienced User
Maybe not for you. But clithes is correct they all work to the AV standard and other people happily use them together.
Perhaps you just had a duff one.
I chip in only to warn people that this is a one-off report that they should treat with caution. There is no "definitely" about it.
