BernardD
Jan 24, 2018Aspirant
AV 500 and PLP 1000 compatible or not compatible ?
Note : it is not possible to select the PLP1000 model in the box here above Hello, I have bought a pair of PLP1000-100FRS powerline adapters. I aleary have a powerline nerwork with three AV5...
- Feb 01, 2018
I have exchanged the CPL1000 for CPL12000.
CPL1200 works.
CPL1000 is definitly not backward compatible.
edsmith0491
Feb 10, 2018Aspirant
IT JUST STOPPED WORKING
I HAVE TRIED EVERYTHING BUT MY POWERLINE WILL NOT CONNECT TO ROUTER.
THE ROUTER IS OK
THE LIGHTS ON THE POWERINE ARE OK -SOLID BLUE AND GREEN
BUT NO CONNECTION
WHAT CAN I DO?
michaelkenward
Feb 10, 2018Guru - Experienced User
Sorry, no instant answers, just a few comments.
First, "tried everything" lacks detail. We don't know which Powerline plugs you have or what they are connected to and what you have tried.
Secondly, you have joined in on an older discussion, so there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
As the previous stuff is marked as SOLVED there is even less chance that Netgear's support team will see your message.
Oh, one more thing, NO NEED TO SHOUT.
