Mayagrafix's avatar
Mayagrafix
AV200 kaput?
Had this kit for just about a year, it has worked flawlessly untill today. It now fails to make a connection (no green or amber light in the Powerline Led). I switched both modules on and off, and even reset to factory specs.
If I bring modules (XAV200 and XAVN2001) into same room they connect beautifully.
What gives?
  • if works in the same room then something is causing on different breaker.
    look all the appliance that is plug on circuit and remove and test again.
  • Thanks for advice. I ran netgear utility software and reset all specs again to factory, this did the trick and AV200 is conecting again. Hope this does not happen again!
