luellen1
Nov 14, 2018Aspirant
av200 powerline compatibility
We have the r6400 and some old powerline av200 extenders. We wanted to try to use them together to get the internet signal up to a far upstairs bedroom or our basement but when we follow the set up ...
antinode
Nov 14, 2018Guru
> We have the r6400 [...]
Hardware version? ("R6400"? "R6400v2"?) Firmware version?
> Model: R6400v2|AC1750 Smart WiFi Router-802.11ac Dual Band Gigabit
Is that accurate?
> [...] and some old powerline av200 extenders.
"Some"? Is that the actual model number?
> [...] when we follow the set up instructions [...]
Which "the set up instructions"? What, exactly, did you do? What,
exactly, happened whan you did it?
> [...] plug the ethernet cable into our router and plug into our
> extender at the other end, [...]
"into our router"? Which port? What, exactly, is connected to what,
exactly?
> [...] Are they not compatible?
Generally, Ethernet is Ethernet; compatibility is not the problem.
Configuration of all these gizmos might be.
