Bryan45
Sep 27, 2014Aspirant
AV200 XAVN2001 Powerline LED will not light
I have AV200 Extender and AV200 Adaptor and have repeatedly tried to set these up without success. I have tried them in every socket in my house. I have tried them in socketd the same room. I have...
michaelkenward
Sep 30, 2014Guru - Experienced User
Bryan45 wrote:
I am using a BT Homehub 2
I'm not familiar with that one. I use a Homehub 4 to feed my Powerlines.
I see that it claims to deliver Gigabit Ethernet. Have you tried the various LAN outlets, just in case there is a fault? Do the LAN sockets light up when you connect to the Powerline?
Can you connect anything of a LAN nature, maybe a laptop, to one of those LAN ports, just to check that it is functioning properly?
What is at the other end of the Powerline link? Is that configured to use the LAN? I ask because I use a BluRay player and a media player that both do wifi or LAN. I have to tell it which to use.
I'm also not familiar with those Powerlines. I have newer versions, but these won't light all the indicators unless there is something going on.
