sakendrick
Jan 13, 2019Aspirant
Bandwidth reliability for streaming TV - Confused about options
Hi There - I'm confused about the Netgear powerline product/bundle options.
Background - I have a Nighthawk 1900 router in a sprawling bungalow.. nothing massive but speed test drop substa...
sakendrick
Jan 14, 2019Aspirant
OK - good on the second question... so yes, I suppose I could connect a regular access point at end of powerline but, then I still have to buy a 2nd bundle of two powerline outlets and also buy an access point. I might as well just get the one with the wifi access point. Thanks for the response.
michaelkenward
Jan 14, 2019Guru - Experienced User
Only you know how big a space you need to fill with wifi, but a Powerline AP plug is bound to be less powerful than something like an Orbi router.
I like simple. But not knowing what you mean by a "Nighthawk 1900" router, it is hard to tell what you can expect from your current setup. I assume that 1900 means AC1900. But that is a wifi speed label, tagged on to about half a dozen different routers.
- sakendrickJan 14, 2019Aspirant
yes... AC1900 (R7000)
