jayburn84
Aug 11, 2018Tutor
Best PowerLine Model to Extend/Boost WiFi in House
Last night we purchased the PLP2000 Powerline 2000 for our home to extend our internet downstairs. I did not realize until we got home that this model seems to only be for adding connections via ethe...
Aug 12, 2018Guru - Experienced User
As far as powerline goes, pure powerline extends ethernet - not wifi. Netgear does has two models that combine powerline with a Wifi access point. Those are the PLW1000 and PLW1010. They are easily distinguished because the wifi module has external antennas. They are one option, though the WiFi speed won't reach your 300 mbps download. They are N300 devices - max link speed of 300 mbps, with throughput being much lower. I'd expect around 90 mbps - though this depends the details of your wiring and circuit loading.
You could combine the PLP2000 with a WiFi access point (giving you better performance than the combo unit). Many netgear extenders (and routers for that matter) can also operate as access points.
So one strategy is to purchase an extender, and see if it solves your coverage problem. If it isn't enough, then switch to AP mode, and use the PLP2000 to connect it to the router. If it is enough, then return the PLP2000.
jayburn84 wrote:
I have not opened the box and will most likely be bringing it back tomorrow to get a WiFi Extender... I am just not sure which to get.
The best performing extender is the EX8000. It's free-standing and about the size of a router. The best performing "wall wart" is EX7500. These could be overkill - they could have more advanced wifi than your router, and of course you might not want to pay for the best possible performance. What router model do you have?
BTW, another approach is to get an Orbi RBK40 system, and use that to provide your home wifi (turning your router's wifi off). Then you could add a second satellite later on if needed. That is more expensive than the EX8000 though.
- jayburn84Aug 12, 2018Tutor
Thanks for the help! We have the Arris TG1682G, I did not want to post any names if there are any forum rules. This is the 3rd modem our ISP has given us (you could probably guess who), the ISP made us return our older Arris Modem we had connected to a small NetGear WiFi router we had. I honestly do not remember the WiFi strength in the areas I spoke about.. mainly because everything was working great and we did not have our Roku/Firesticks in the areas we now have issues in.
Our current Arris TG1682G works okay, it is pretty stable considering who the ISP is and the congested area we live in (North NJ). But it's quite sad when our neighbors who live behind us, probably guessing 50-60yards away (not exactly sure.. suburbs are tightly packed, and I just happen to know my neighbor/friend's network SSID heh.)
The ISP ran the line from the street pole to my office which is on the 2nd floor and on the side of the house... I've done speedtests walking around the house and thought maybe the modem/router unit was just in a bad location, but downstairs our WiFi is generally 300mbps down, all besides the kitchen and downstairs living room (kitchen is 1 floor down (50+ft maybe ?? and the downstairs is probably 50-75ft as well)... hard to tell the downstairs living room as it kind of right below the room the modem/router is in.. but gets awful WiFi speeds.
90-100mbps would be more than enough. I've noticed that our PC's we have hardlined via ethernet cable only pull 100mbps downstream, and we're lucky to get 25mbps upstream. But I game on my PC and do not nor can afford disconnects, I never game over WiFi.
The kitchen WiFi generally streams Netflix, Hulu, and other services perfectly fine but does have interuptions (randomly), and the Live TV App our Cable Provider (same as our ISP) they recommended to us to try out buffers and disconnects consistently, making television viewing impossible. It's like the terrible speed/low level of bars in the kitchen are tricking the Roku into thinking No WiFi connection... unless we reboot the device, then it generally reconnects 99% of the time on the 1st reboot.
I think I am going to try the cheapest route, the other unit I saw may have been one of the two you mentioned, it was right next to the Powerline 2000 I picked up. The store had some other extenders and such in the next aisle.
I was actually wrong on what our old Router was, it was actually a Linksys WRT54GL. I just found it lying around. I remember we tried once to plug it into one of the hard lines downstairs, and use it as possibly what you would call an Access Point (AP), but for some reason it was giving us issues, not sure why but it would disconnect and give slower speeds than we had hoped. That was a long time ago and I was always hoping that would have helped, but I remember it wasn't really helping so we scrapped that plan.
- StephenBAug 12, 2018Guru - Experienced User
jayburn84 wrote:
We have the Arris TG1682G, Arris TG1682G
Ok. As far as I can see that's dual-band 802.11n router. New routers use 802.11ac, and the high-end models are triband. The EX8000 would certainly work, but would be overkill. The combo unit should be fairly inexpensive (and you could add a second one if you need it).
50-75 feet is a long run for wifi, but of course the living room should be getting good coverage.
There could be a hole in the coverage directly over and under the router (often dipole antennas coverage looks like the figure below).
So you could try shifting the unit a bit, and see if that helps.
Construction can also make a big difference (fireplaces, pipes in the wall, metal studs, etc).
Hmm, yeah I had moved the Modem/Router as much as I could. Luckily I've got enough ethernet cable length for the 3 cables we ran downstairs, no issues with the PC in my room I keep hardlined (same room as router). But unfortunately, we could only move it across the room (more centered in the house now). It helped a little, but the kitchen still is the worst WiFi area of the house. This is not a large house heh.
I returned the Powerline 2000, I was looking at the PLW1000 and they had the NightHawk EX7000 (did not see the 8000). I decided to purchase the EX7000, it did not cost much more than the PLW1000. If it doesn't help, the store has it's 14 day Return Policy. I hope it can really help downstairs, I will certainly document what happens.
I keep my 2nd PC which is located in the same room as the Router/Modem connected through a Netgear WN3000RPv3 which works great. I just did not have an extra hardline available out of the router, and the 2nd PC is really only used for media, web browsing, and basically a backup incase my main PC ever goes down god forbid. The WN3000 works great, but like I said it's also in the same room as the Modem/Router.
It saves me an ethernet port which is great. We tried the WN3000 downstairs a few months back and due to the bad WiFi reception it was a nightmare for the PC we had it connected to, so we ran a hardline to that PC and I still have an extra WN3000 laying around in case we ever need to run something somewhere else in the house.
I am about to try finding the right spot downstairs for the EX7000, crossing my fingers it resolves some issues. If not, I will most likely have to call the ISP and have them run another line to the house, more centered, possibly downstairs, but that is a project I am trying to avoid considering all of our ethernet cables are run to this room... always have been. We had the ISP run the line almost 2 decades ago, it's never had an issue, location was never an issue, but that was way before the WiFi and Streaming Era... so nobody expected this :(
