jayburn84
Aug 11, 2018Tutor
Best PowerLine Model to Extend/Boost WiFi in House
Last night we purchased the PLP2000 Powerline 2000 for our home to extend our internet downstairs. I did not realize until we got home that this model seems to only be for adding connections via ethe...
jayburn84
Aug 12, 2018Tutor
Thanks for the help! We have the Arris TG1682G, I did not want to post any names if there are any forum rules. This is the 3rd modem our ISP has given us (you could probably guess who), the ISP made us return our older Arris Modem we had connected to a small NetGear WiFi router we had. I honestly do not remember the WiFi strength in the areas I spoke about.. mainly because everything was working great and we did not have our Roku/Firesticks in the areas we now have issues in.
Our current Arris TG1682G works okay, it is pretty stable considering who the ISP is and the congested area we live in (North NJ). But it's quite sad when our neighbors who live behind us, probably guessing 50-60yards away (not exactly sure.. suburbs are tightly packed, and I just happen to know my neighbor/friend's network SSID heh.)
The ISP ran the line from the street pole to my office which is on the 2nd floor and on the side of the house... I've done speedtests walking around the house and thought maybe the modem/router unit was just in a bad location, but downstairs our WiFi is generally 300mbps down, all besides the kitchen and downstairs living room (kitchen is 1 floor down (50+ft maybe ?? and the downstairs is probably 50-75ft as well)... hard to tell the downstairs living room as it kind of right below the room the modem/router is in.. but gets awful WiFi speeds.
90-100mbps would be more than enough. I've noticed that our PC's we have hardlined via ethernet cable only pull 100mbps downstream, and we're lucky to get 25mbps upstream. But I game on my PC and do not nor can afford disconnects, I never game over WiFi.
The kitchen WiFi generally streams Netflix, Hulu, and other services perfectly fine but does have interuptions (randomly), and the Live TV App our Cable Provider (same as our ISP) they recommended to us to try out buffers and disconnects consistently, making television viewing impossible. It's like the terrible speed/low level of bars in the kitchen are tricking the Roku into thinking No WiFi connection... unless we reboot the device, then it generally reconnects 99% of the time on the 1st reboot.
I think I am going to try the cheapest route, the other unit I saw may have been one of the two you mentioned, it was right next to the Powerline 2000 I picked up. The store had some other extenders and such in the next aisle.
I was actually wrong on what our old Router was, it was actually a Linksys WRT54GL. I just found it lying around. I remember we tried once to plug it into one of the hard lines downstairs, and use it as possibly what you would call an Access Point (AP), but for some reason it was giving us issues, not sure why but it would disconnect and give slower speeds than we had hoped. That was a long time ago and I was always hoping that would have helped, but I remember it wasn't really helping so we scrapped that plan.
Aug 12, 2018Guru - Experienced User
jayburn84 wrote:
We have the Arris TG1682G, Arris TG1682G
Ok. As far as I can see that's dual-band 802.11n router. New routers use 802.11ac, and the high-end models are triband. The EX8000 would certainly work, but would be overkill. The combo unit should be fairly inexpensive (and you could add a second one if you need it).
50-75 feet is a long run for wifi, but of course the living room should be getting good coverage.
There could be a hole in the coverage directly over and under the router (often dipole antennas coverage looks like the figure below).
So you could try shifting the unit a bit, and see if that helps.
Construction can also make a big difference (fireplaces, pipes in the wall, metal studs, etc).
- jayburn84Aug 12, 2018Tutor
Hmm, yeah I had moved the Modem/Router as much as I could. Luckily I've got enough ethernet cable length for the 3 cables we ran downstairs, no issues with the PC in my room I keep hardlined (same room as router). But unfortunately, we could only move it across the room (more centered in the house now). It helped a little, but the kitchen still is the worst WiFi area of the house. This is not a large house heh.
I returned the Powerline 2000, I was looking at the PLW1000 and they had the NightHawk EX7000 (did not see the 8000). I decided to purchase the EX7000, it did not cost much more than the PLW1000. If it doesn't help, the store has it's 14 day Return Policy. I hope it can really help downstairs, I will certainly document what happens.
I keep my 2nd PC which is located in the same room as the Router/Modem connected through a Netgear WN3000RPv3 which works great. I just did not have an extra hardline available out of the router, and the 2nd PC is really only used for media, web browsing, and basically a backup incase my main PC ever goes down god forbid. The WN3000 works great, but like I said it's also in the same room as the Modem/Router.
It saves me an ethernet port which is great. We tried the WN3000 downstairs a few months back and due to the bad WiFi reception it was a nightmare for the PC we had it connected to, so we ran a hardline to that PC and I still have an extra WN3000 laying around in case we ever need to run something somewhere else in the house.
I am about to try finding the right spot downstairs for the EX7000, crossing my fingers it resolves some issues. If not, I will most likely have to call the ISP and have them run another line to the house, more centered, possibly downstairs, but that is a project I am trying to avoid considering all of our ethernet cables are run to this room... always have been. We had the ISP run the line almost 2 decades ago, it's never had an issue, location was never an issue, but that was way before the WiFi and Streaming Era... so nobody expected this :(
After synching the Nighthawk EX7000 in my room with the ISP's modem/router, I brought it downstairs to the center of the house, roughly 3-5 feet from the kitchen (problem area) and plugged it in and placed it on the TV stand next to the TV we have hooked up to an Xbox. The Xbox has never had an issue with WiFi connectivity, so I just left it alone.
I immediately noticed the 2 areas of the house that had previously had horrible WiFi (averaging 10-20mbps downstream/very unstable too). I connected to our new "network"_5Gext with my cell phone and did several speedtests walking around, everything is now up to around 55-60mbps on average, give or take. Same with the room all the way on the farthest side of the house where we have a PC hardlined in, my phone would get roughly 25mbps downstream on average in that spot, but while connected to the _5Gext it was getting about 60mbps downstream.
So right away I can tell the difference with the Nighthawk EX7000 connected, and it is certainly helping. It was very easy to setup, I feel I have it in the best place possible for the house, I may try another spot... but for the time being I truly believe the trouble areas that were barely getting 10-20mbps downstream are now getting 60+ mbps downstream is a huge improvement.
Our modem/router does put out 300mbps downstream if you test it over WiFi and are in a "good" spot of the house. I could not replicate that over the EX7000, so for those areas I suppose we will just keep any devices connected directly to the modem/router. But I am certainly happy that the kitchen as well as the farside of the house and downstairs are certainly better.
I was reading the instruction manual and was considering the route of trying to plug the NightHawk EX7000 into the hardline on the farside of the house and using it as a router/AP, but was a little confused and wanted to try the EX7000 without doing that. I am curious as to whether that would still be the best method to go, or to stay the way we are now.... it's pretty simple and easy to connect to our new _2Gext & _5Gext. We also have a previously installed _ext (from our WN3000 in an outlet in the same room as the modem/router). I only use the WN3000 for my 2nd PC which does not have WiFi capability. My 2nd PC has a short network cable running from the WN3000 plugged into the wall to it and I've never had any issues with it, however the WiFi signal put out from the WN3000 regardless of where we plugged it into the house was honestly not great anywhere.
I am liking this EX7000, it wasn't too expensive, very easy to setup, and I am sure if I move it around I may find a better spot, but for the time being it's working great. I am not sure if it is recommended to use it the "other way", which was to possibly plug it into an existing ethernet line, then to basically just set it up as a router... I would think that may actually be better... if it was connected directly to our modem/router hardlined in on the far side of the house, it should probably put out an even stronger signal no? Either way, very happy I purchased this... I just need to study it a little more.
After trying a few features on the Extender in "Extender" mode, I think I am going to stick to the Basic Mode in regards to the FastLane Technology. I tried both, I tried each setting (2.4 vs 5) in FastLane Tech Mode, I did see a slight increase in speeds throughout the house... but then something happened and my EX7000 either lost connection to my modem/router, or it was just confused but I could not connect to the internet and was having issues.
I reset the device, and have it back in Basic Mode. I thought it'd be easier just to have one extension network available... but whatever happened I'm not sure. I am back to having both the 2GEXT and 5GEXT... I will be leaving it like that for now. As for the speeds in our "dead" zones that were barely pulling 20mbps downstream, they are getting 80mbps + in those spots now while connected to either 2GEXT or 5GEXT, which was exactly what I was seeking.
I am still convinced our house is possessed, while connecting back to the main modem/router I noticed the strength of our main network at 80%sh drop to 35%sh, without moving anything. Right now it's sitting in the mid to high 70%'s downstairs in it's new home. I do notice the green lights go amber every now and then, which is just odd. I guess there is a ghost floating around this house... or maybe our modem is just that shotty, because I know the newly purchased Netgear Extender is working 100% as it should.
If I had more time I would try Access Point mode while connected to the hardline ran on the far side of the house. I am not sure if that will make the WiFi even stronger, or just extend a bit further.. I am really curious to see what it does and how it performs... but I have done enough today for my brain, maybe next weekend. If anyone has any feedback regarding Extender Mode vs AP Mode for a situation like ours, where the ISP's Modem/Router is stuck all the way to one side of the house, giving us issues on the far-side of the house/kitchen please let me know what you think would be best. We are fortunate enough to have a hardline ran to the other side of the house that I could test.
