paul_paterson
Oct 14, 2017Aspirant
Blue light flashing
I have conect a Netgear Powerline PL1000 internet extender to a Netgear CG3000-1STAUS modem router via an ethernet cable. I have run the security setup/connection on hte device = Powereline and as r...
- Oct 18, 2017
The lights on the CG3000-1STAUS modem router will have nothing to do with the powerline plugs.
Which light is flashing blue?
Manuals and stuff here:
>> Click here >> CG3000-1STAUS | Product | Support | NETGEAR << Click here <<
Looks like those lights may be something to do with your ISP connection. What happens when you unplug the powerline device?
michaelkenward
Oct 18, 2017Guru - Experienced User
- paul_patersonOct 25, 2017Aspirant
Many thanks for the prompt reply, most helpful. The blue light has no bearing on function. All is good. Paul
