Spectralis1's avatar
Spectralis1
Blue light on powerline adapter
I have a blue led on the wifi indicator (powerline adapter) all the time. I have tried different sockets and in the same room as router and  access point. Can see the wifi name but no internet access...
  • JamesGL's avatar
    JamesGL
    Aug 17, 2016
    Hi Spectralis1,
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    JamesGL
    Community Team
