Suffolkone
Dec 30, 2016Aspirant
Buffering problem with Powerline 500 Adapter XAVB5201
Can anyone out there help with my problem please. I am using a Netgear Powerline 500 Mbps ( Home Plug) Adapter ( XAVB 5201) plugged directly into a Power Socket near my Sony Smart TV. This i...
clithes
Dec 31, 2016Prodigy
My mum has exactly the same problem with her Humax every now and then.
Unfortunately you cannot record/download tv programmes on the Humax when accessing onDemand, but you can let it get ahead of itself by pressing pause once you've selected the programme.
Leave the programme on pause for a minute or two then press play again. This should download enough of a buffer so the Humax doesn't stutter any more
Hope this helps
Suffolkone
Dec 31, 2016Aspirant
Thanks very much for your quick reply and good suggestion.
Will give it a try today and see if it helps.
Have a Happy New Year !
- michaelkenwardDec 31, 2016Guru - Experienced User
Is the smart TV wired or wifi? (I can't work out what is connected to what.) I use wired Powerline for my smart BluRay player. I never see any buffering.
- SuffolkoneDec 31, 2016Aspirant
Thanks for reply.
My set up is as follows.
Sony Smart Tv connected by cable to Humax Sat Box.
Humax Sat Box connected by Ethernet Cable to Powerline 500 Adapter in Mains Socket.
Netgear Broadband Router Box connected by Ethernet Cable to Powerline Adapter in Mains Socket ( in another room).
Hope this explains.
No Internet connection for the smart TV? I would have expected LAN or wireless.
