stereojeff
Nov 22, 2018Aspirant
Can the 2 ports on the PLP2000 endpoint adapter "talk" directly to each other?
Am setting up a very upscale audio system that uses a server and streamer that don't do WiFi. So my preferred option is the buy the PLP2000 (disregard stated model number above, could not enter PLP2...
michaelkenward
Nov 23, 2018Guru - Experienced User
Not sure that I follow, a diagram would help, but the "remote" plug with two ethernet ports
PLP2000 | Powerline | Networking | Home | NETGEAR
works though the router.
The two ports won't talk to each other so much as work like everything else on the network and talk through the router. The devices on them have to get an IP address from somewhere, and the plugs don't do that.
Maybe even a small switch would work. I haven't tried that with powerline.
stereojeff
Nov 23, 2018Aspirant
Thanks for the reply. I think you understand the intent of my posting. As an audio purist, I should hardwire but my electrician can't do the installation until January, so the server vendor suggested HomePlug technology as neither the server nor the streamer have a wireless option. So was hoping that the two devices connected to the two ports on the PLP2000 would have a direct connection going just through the endpoint adapter without traveling via hundreds of feet of house wiring back and forth through the router.
Unfortunately your answer makes sense and in hindsight the whole HomePlug approach 'scares' me as an audio purist.
