stereojeff
Nov 22, 2018Aspirant
Can the 2 ports on the PLP2000 endpoint adapter "talk" directly to each other?
Am setting up a very upscale audio system that uses a server and streamer that don't do WiFi. So my preferred option is the buy the PLP2000 (disregard stated model number above, could not enter PLP2...
stereojeff
Nov 23, 2018Aspirant
Thanks for the reply. I think you understand the intent of my posting. As an audio purist, I should hardwire but my electrician can't do the installation until January, so the server vendor suggested HomePlug technology as neither the server nor the streamer have a wireless option. So was hoping that the two devices connected to the two ports on the PLP2000 would have a direct connection going just through the endpoint adapter without traveling via hundreds of feet of house wiring back and forth through the router.
Unfortunately your answer makes sense and in hindsight the whole HomePlug approach 'scares' me as an audio purist.
michaelkenward
Nov 23, 2018Guru - Experienced User
I doubt very much if you'll notice any impact on your audio.
The bandwidth needed for audio is minimal. If people mange to stream video over powerline, as I do, then audio is a piece of cake. I've done that too, albeit not over mile long links.
Anyone even willing to contemplate using wifi should find Powerline satisfactory.
The real problem is more likely to be the quality of the mains circuit.
