DerrickO
Feb 06, 2016Aspirant
Cant configure 500 Wifi with Net Genie on Mac
HI all, having some trouble. Actually, I'm not even sure if what I bought thos Powerline for is doable (kind of a bridge mode thing.) Here's what I have: • Att 2Wire router in the front of the h...
DerrickO
Feb 08, 2016Aspirant
Awesome. Thanks so much!
Provided I can configure it, this setup should work with the XVN unit getting signal from the plug outlet then transmitting WifI? It doesn't have to be in wifi range of my ATT2wire in the front of the house, correct?
clithes
Feb 08, 2016Prodigy
Yes thats right the Wi-fi extender is getting its internet connection through the powerline adapters, and then broadcasting its own Wi-Fi signal. So as long as the two adapters connect it doesn't matter how far they are away from each other. You can therefore use your router to provide a Wi-Fi connection at one end of the house and the extender at the other (depending on how big your house is, obviously!)
