Jasek
Nov 20, 2017Aspirant
cant get the powerline adapter to work in my out building
Heres the deal, I have an out building that is approximately 100 feet away from the house. I set up the inside unit to the router, and set up the other unit in my out building, It shows that there ...
clithes
Nov 20, 2017Prodigy
Even though it's the same power supply, do you have a mini consumer unit / isolator in the outbuilding ? This could be causing the problem
Jasek
I am not sure what you mean by the mini unit?
- clithesNov 20, 2017Prodigy
Can you isolate the electricity in the outbuilding as it has it's on circuit breakers?
- JasekNov 20, 2017Aspirant
The Main triplex comes in from the road, goes to the entrance on the house, which then goes to an outside breaker panel, this then splits it to the house and the garage, all of which go overhead.
Since the power on the property comes from only one incoming source, Shouldnt they all be connected som how? which i thought would allow the powerline netgear units to communicate. so i assume that the circuit breakers are what is causing the isolation then?
