J-Valjean24601's avatar
Feb 10, 2016
Compatible powerline adapter
Hi Everyone
At present I have 2 Netgear powerline 600 XAV6501 to receive IPTV. I would like to put another TV in another room and wish to know which adapter will be compatible with the XAV6501.
I have searched the internet and there is a dazzling array of adapters and obviously I do not want to purchase an adapter which is not compatible.
Being new to this site I hope I have included all the information required.
Thanking you in advance for any advice offered.
  • Your current model is HomeplugAV standard, so any other powerline adapter that is HomeplugAV or the newer HomeplugAV2 standard will work with it (HomeplugAV2 is backwards compatible with HomeplugAV)
    Most new powerline adapters will be HomeplugAV or HomeplugAV2 standard.
    Hope this helps
    Hope this helps
