srini007
May 15, 2016Aspirant
Compatible powerline adapter
I currently have a XAV101 v2 powerline adapter If i want to buy another powerline adapter, is there is a compatilbility list that will work with current XAV101 v2
michaelkenward
May 17, 2016Guru - Experienced User
They all follow an industry standard and will work together. Even different brands.
You have an early model that is slower than the kit sold today.
"Up to 200 Mbps with real throughput greater than 80 Mbps"
This will limit the speed that you get with the newer, >500 Mbps, models. But they will still work.
- srini007May 20, 2016Aspirant
Thanks - I will try
- michaelkenwardMay 20, 2016Guru - Experienced User
Good luck. It has worked here. Different standards (speedwise) and different brands. They all talk to one another.
