Gabriel_Iordach
Nov 26, 2016Aspirant
Configuration question
I get internet from Bell Canada through a wireless router that covers my living room. I use a Powerline 500 to get signal into my bedroom - which is accessed through a narrow corridor from the living...
TheEther
Nov 27, 2016Guru
I'm not sure, but it sounds like your description is missing a detail or two. Do you have a Netgear router in addition to your Powerline 500, or do you just have the Powerline 500? Is your Bell Canada router a Netgear?
The reason I ask is that the Powerline 500 does not have a built-in DHCP server so it cannot assign IP addresses. I'm not sure where you thought you disabled DHCP. You mentioned you used Genie to disable DHCP and that Genie doesn't see your router, which is why I suspect you omitted a detail.
- Gabriel_IordachNov 27, 2016Aspirant
Thank you for the quick reply. Here are the answers:
1/ I don't have any other Netgear routers (that I know of, it might be that one of thetwo components of what I call the Netgear Powerline AV500 is a router). The Bell modem is made by Sagem. The Netgear Device I have is identified as XWN5001.
2/ very hard to give you an answer here. I might have mis-remembered. If this is the case: I apologise. However: Can you tell me what I need to do to get to my goal (which is having just one network in the house?). Today in LAN port I can see DHCP is "on".
Here are details about the XWN5001:
Hardware Version 1.00
Firmware Version V0.3.0.9NA
GUI Language Version V1.0.0.6 and then:
MAC Address 28:C6:8E:08:CF:CD
DHCP On
IP Address 192.168.2.26
IP Subnet Mask 255.255.255.0
Gateway IP Address 192.168.2.1
Domain Name Server 192.168.2.1 - Gabriel_IordachNov 27, 2016AspirantI am trying to make myself clear: 1/ my goal is to move from the livingroom to the bedroom without having to move from the Bell network to the Netgear network. 2/ if The device I have is not a router, why is my iPad switched to a Netgear WiFi network when I move to the bedroom?
- TheEtherNov 27, 2016Guru
Configure your Powerline 500 with the same SSID and Wi-Fi password as your Bell Canada router. Use a different Wi-Fi channel. Use only channels 1, 6 or 11 for best results.
- michaelkenwardNov 27, 2016Guru - Experienced User
Gabriel_Iordach wrote:
if The device I have is not a router, why is my iPad switched to a Netgear WiFi network when I move to the bedroom?Your portable device is doing what it is designed to do. It is switching from one wifi source to another one that is providing a better signal.
Think of it this way, you have two wifi sources. You probably did this because the main wifi source isn't strong enough in the bedroom. As you walk from one wifi source to the other, your device has to switch sources.
Somewhere between the two it will see equal signals. There will also be an overlap region where either source will deliver a decent connection. It is down to your device to make the decision, not the sources. They just sit there chucking out the Internet for you to connect to.
The fact that you have trouble may be down to the mobile device rather than the wifi sources. So maybe Apple should also get some of your understandable anger.
Some people suggest using the same SSID and password for nearby wifi sources. This can be a bad idea because mobile devices can get confused and "hunt" between the two. They don't know which one to latch on to. (That's probably why adds _EXT to SSIDs for extended networks.) Certainly try that, I always use the same password for different local SSIDs, but be prepared for disappointment.
A properly configured mobile wifi device will quickly connect to the best signal it sees. It will also remember wifi sources that it has seen and will connect to the best source with no intervention and without you noticing that anything has happened. That is how my Android devices work with the various powerline plugs and routers I run. (Mine is complicated by having two separate phone lines and internet services.)
From the symptoms you describe, your problem is not just the wifi sources. But my first suggestion would be to investigate the settings on your portable wifi devices. There aren't many iPeople here, so you might want to consult other Apple places for help with configuring wifi on your devices.
By the way, which Netgear genie are you talking about? There is a confusing choice of genies: desktop (Windows), Android, iThing. Unfortunately, they might not play nicely with hardware that isn't Netgear.
What you say makes a lot of sense, and I agree with you that some of the anger is misplaced... until I remember that a product should be designed in such a way as to minimise client frustration... (I can tell you there's aton of frustration).
This issue can be adressed in two different ways:
1/ The solution I propose: (I call it good network design): here the Powerline acts as an Access Point. There has to be a good design where I don't have to go for the same SSID for two networks... I see your point about the device getting confused on choosing between the two.
2/ Good device design, where the stupid HP PC/iPad/HTC or Samsung smartphones know that therre are 2, or 3 or 5 networks that are used in the same locale, checks the strength of each, and seamlessly hops between them to give me the best signal. I guess that in the current implementation the devices moves from a network when the signal strength gets to be about zero... I agree with you that from an ecosystem perspective, this is the right place to fix/address the issue. My assumption is that this is a sympton of growing pain (i.e. will get fixed in another 5 to 10 years when new protocols / standards emmerge).
Therefore, yes: APPLE sucks (and HP and HTC, and Samsung, and then again Apple - we have lots of devices ). However, please remember that I wasted my time trying to get past the admin login screen in the Genie app, so some of the anger is justified.
Also: do you have any thoughts about why I cannot log into the Genie admin account? I've done this using the browser (the 192.168.2.26 thing)... just not using the Genie software (only used the PC version of the software).
To summarize:
1/ I will try to play with the iPad/windows/android software and see if there's anything there to make the respective devices jump networks faster/earlier, and
2/ I will try anything you tell me to do in Gennie to get past the admin login screen,
3/ if all falls, I will try to have the sameSSID on the Netgear network as the one currently on the Bell network (and use the same credentials - as I understand it, this is what the same SSID thing is).
Thank you for your help,
Gabriel
