EricLevinson
Apr 07, 2021Initiate
Did a factory reset on my PLW1000 V2 - now default admin / password does not work
I was having erratric results from connectivity and decided to do a hardware factory reset by putting a paperclip in the hole and holding it for 15 seconds. Unit reset ok - and I can connect to t...
- Apr 07, 2021
antinode I already read the manual and it says the factory default username is admin and the factory default password is password.
Yes - originally I was able to set the unit up with admin / password and put in a custom password - I tried that one as well and it didn't work.I just noticed there are two versions of this device PLW1000V2 - there's an older one (which I have) and a newer one that has the password set to password.
The older one password is the same as the default wifi password. I just tested it and it works.
Thanks for your help.
antinode
Apr 07, 2021Guru
> [...] I entered in the default username and password, "admin" and
> "password" and the unit says its invalid.
Ok.
> I also tried my previous password - and it too is invalid.
A "my previous password" which you had chosen, or something else?
> Any help would be greatly appreciated.
You might try an under-appreciated resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Customize Your Network Settings", and "3. Enter the user name admin and
the password. [...]".
Did you try all the various possibilities?
EricLevinson
