EricLevinson
Apr 07, 2021Initiate
Did a factory reset on my PLW1000 V2 - now default admin / password does not work
I was having erratric results from connectivity and decided to do a hardware factory reset by putting a paperclip in the hole and holding it for 15 seconds. Unit reset ok - and I can connect to t...
- Apr 07, 2021
antinode I already read the manual and it says the factory default username is admin and the factory default password is password.
Yes - originally I was able to set the unit up with admin / password and put in a custom password - I tried that one as well and it didn't work.I just noticed there are two versions of this device PLW1000V2 - there's an older one (which I have) and a newer one that has the password set to password.
The older one password is the same as the default wifi password. I just tested it and it works.
Thanks for your help.
EricLevinson
antinode
Apr 07, 2021Guru
> [...] I already read the manual and it says [...]
Which "the manual"? Read it again? Fetch a recent copy, and read it
again?
As I read the manual, you have "older" and "newer" reversed, but, ...
> [...] I just tested it and it works.
So long as one of them works, that's what matters most.
