EricLevinson
Apr 07, 2021Initiate
Did a factory reset on my PLW1000 V2 - now default admin / password does not work
I was having erratric results from connectivity and decided to do a hardware factory reset by putting a paperclip in the hole and holding it for 15 seconds. Unit reset ok - and I can connect to t...
- Apr 07, 2021
antinode I already read the manual and it says the factory default username is admin and the factory default password is password.
Yes - originally I was able to set the unit up with admin / password and put in a custom password - I tried that one as well and it didn't work.I just noticed there are two versions of this device PLW1000V2 - there's an older one (which I have) and a newer one that has the password set to password.
The older one password is the same as the default wifi password. I just tested it and it works.
Thanks for your help.
zowieforthright
Jun 19, 2025Aspirant
Just wanted to say the same thing happened to me this morning and it was driving me crazy. I checked the user manual (which says the login is admin/password) and even asked ChatGPT - but using the default network password as the login worked. It was not enough to just 'like' your solution, so I had to create an account just to say THANK YOU! Still relevant in 2025
