BernieUK's avatar
BernieUK
DNS issue on LG Smart TV! Any help or advice would be appreciated.
Greetings all!   I will try and keep it short and sweet!   I am using 3X Powerline 500 XAVB5221. One is connected to the router and main PC, the second to a laptop the third is an LG Smart TV. Th...
  • netwrks's avatar
    Mar 24, 2016
    I would try giving the TV a static IP address including DNS Server addresses and try again. Give the TV a high IP address, soething like 192.168.x.250, so that you do not end ip with a conflicting IP address scenario. You should also be able to add yourDNS Servs in the manual config of the TV.
