BernieUK
Mar 24, 2016Aspirant
DNS issue on LG Smart TV! Any help or advice would be appreciated.
Greetings all! I will try and keep it short and sweet! I am using 3X Powerline 500 XAVB5221. One is connected to the router and main PC, the second to a laptop the third is an LG Smart TV. Th...
- Mar 24, 2016
I would try giving the TV a static IP address including DNS Server addresses and try again. Give the TV a high IP address, soething like 192.168.x.250, so that you do not end ip with a conflicting IP address scenario. You should also be able to add yourDNS Servs in the manual config of the TV.
netwrks
Mar 24, 2016Master
BernieUK
Thank you for the reply. Much appreciated.
