liv2hunt
Feb 15, 2019Tutor
Extender not working correctly
I have recently purchased the Range extender (adapter) listed above. It is connected via ethernet to my router which functions well and is located in my living room and produces (dual band) readings ...
- Feb 17, 2019
Problem solved. I only had to change the connection on the camera from the original wifi (router) to the ext network created by the Netgear extender.
Guess that should have been the first thing I did but sometimes, we have a brain fart!
Anyway, thanks for the help.
liv2hunt
Feb 16, 2019Tutor
Yes, it is the PLW1010 listed iin the footer.
You have completely answered my original question. The scenarios you gave are spot on.
I will further the discussion by explaining what I am trying to accomplish.
I have an alarm based in my house with sensors etc in the garage. I am not getting a good enough signal from my WiFi in the home due to the steel walls of the garage. I installed the PLW1010 to extend the signal inside the garage through the electric cables which run from the house to the garage, thus eliminating the walls problem.
The new problem is that all of the alarm sensors, cameras etc need to be on the same WiFi network, or at least I think that is correct. If I connect to the WiFi in home, its not the same as the ext network in the garage (at least it has a different name) and vice versa.
According to my alarm provider, my signal to the devices in the garage are weak and should be improved.
Could I add another acces point inside the home from the PLW1010 (like adding the "pods" from other manufacturers) and how would that affect the speed of my WiFi inside the home compared to being connected directly to the router?
Thanks for past and future help!
michaelkenward
Feb 16, 2019Guru - Experienced User
I would investigate that. Not knowing what these cameras are, it is hard to know what you need.
If they are cloud based devices, then it should be the internet connection that matters, not the local wifi network.
- liv2huntFeb 16, 2019Tutor
All cameras/sensors are Ring products which connect via WiFi signal.
- michaelkenwardFeb 16, 2019Guru - Experienced User
This might help:
https://shop.ring.com/pages/faq
WHAT ARE WI-FI RANGE EXTENDERS? WILL THEY IMPROVE THE WIRELESS INTERNET CONNECTION TO MY RING™ VIDEO DOORBELL?
A wireless repeater is a stand-alone unit that extends the range of your Wi-Fi signal by repeating the signal over a greater distance. They are simple devices that are easy to connect to your Wi-Fi network. Once connected, position your repeater somewhere near your Ring™ to ensure the best possible signal. We recommend you configure the repeater with a unique network name (SSID) and then connect your Ring™ Video Doorbell to this unique network name.- liv2huntFeb 17, 2019Tutor
