liv2hunt
Feb 15, 2019Tutor
Extender not working correctly
I have recently purchased the Range extender (adapter) listed above. It is connected via ethernet to my router which functions well and is located in my living room and produces (dual band) readings ...
- Feb 17, 2019
Problem solved. I only had to change the connection on the camera from the original wifi (router) to the ext network created by the Netgear extender.
Guess that should have been the first thing I did but sometimes, we have a brain fart!
Anyway, thanks for the help.
michaelkenward
Feb 16, 2019Guru - Experienced User
This might help:
https://shop.ring.com/pages/faq
WHAT ARE WI-FI RANGE EXTENDERS? WILL THEY IMPROVE THE WIRELESS INTERNET CONNECTION TO MY RING™ VIDEO DOORBELL?
A wireless repeater is a stand-alone unit that extends the range of your Wi-Fi signal by repeating the signal over a greater distance. They are simple devices that are easy to connect to your Wi-Fi network. Once connected, position your repeater somewhere near your Ring™ to ensure the best possible signal. We recommend you configure the repeater with a unique network name (SSID) and then connect your Ring™ Video Doorbell to this unique network name.
liv2hunt
Feb 17, 2019Tutor
