Mparadis74
Oct 06, 2020Aspirant
Extender shows wifi connection but does not connect to internet
Extender was working great for 6 months... now it still shows the wifi extender names... but will not connect to the internet.
I have rebooted wifi source, factory reset extender, but eventhough I can see the extender wifi names, will not connect to the internet
What router are you connecting it to?
Are you setting it up via wps or the installation assistant?
what firmware is on it?
- Mparadis74Aspirant
I am using verizon router and setting up with wps... hitting button on extender, then wps on source router
Which verizon router?
did you try using the installation assistant?
Firmware?
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
