Rutschi
Oct 06, 2024Aspirant
Fritz!powerline 540 gastnetz
Ich habe ein ORBI 850 und einem Fritz!powerline 540. Ich habe alles versucht, kann den Gast zugang mit dem fritz WLAN nicht connecten
While there are some cunning linguists here, you might do better to seek help in your language community.
For advice in German, try:
NETGEAR Forum - NETGEAR Communities
Just another user with time on their hands.
- RutschiAspirantI have an ORBI 850 and a Fritz!powerline 540. I've tried everything, but I can't connect the guest access to the Fritz WLAN
Rutschi wrote:
I have an ORBI 850 and a Fritz!powerline 540. I've tried everything, but I can't connect the guest access to the Fritz WLANI assume that the Fritz!powerline is a wireless access point.
The idea of a powerline AP is that it picks up its network access, and settings, from the main router.
Is this guest network set up on the Orbi?
If you are trying to do fancy things with the Fritz!powerline, you'll have to talk to the people who made it.
