RCL's avatar
RCL
FTP for Clients
I set up a FTP on my home computer and I am using the PL1000 model to connect my PC to the internet. My problem is my FTP will not work over the powerline product. I have the ports forwarded to my lo...
  • TheEther's avatar
    May 11, 2016
    Are you implying that FTP works if you plug your PC directly into your router, but it does not work in conjunction with the PL1000?  The PL1000 is just a bridge, so it should not interfere with the IP networking layer.
