Razor7Tech
Jan 26, 2017Aspirant
How Can I Upgrade PowerLine Firmware?
Hello-- I have had several of the older v1 of the Powerlines with no issues for years. I just bought the nano v2 and I'm having trouble with one that keeps losing its connection and I have to kee...
michaelkenward
Jan 30, 2017Guru - Experienced User
There does not seem to be new firmware for that.
XAVB5201v2 | Product | Support | NETGEAR
Can you switch plugs around to see if this is down to the plug, its location or something else?
You could even try different cables.
Razor7Tech
Jan 30, 2017Aspirant
Thanks, but I have done all the typical layer 1 troubleshooting. It is the unit itself. I would like to try to install the firmware regardless of whether there is a new version or not as it is the last effort I'm going to make before returning them.
- michaelkenwardJan 30, 2017Guru - Experienced User
Razor7Tech wrote:I would like to try to install the firmware regardless of whether there is a new version or not ...
If it doesn't exist, you are stuffed.
- Razor7TechJan 30, 2017Aspirant
Already ordered a replacement.
Warranty I hope.
