bayviewfox's avatar
bayviewfox
Follower
May 22, 2024
How many powerline 2000 can use same network?
  • plemans wrote:
    We usually tend to see issues after that 3rd node if they're going to have issues.
    It may depend on the plugs, their model number. I have also see them doing OK until they hit the sixth plug.
    How many are you needing
    A key question. And are they wired or wired/wifi?
    • michaelkenward's avatar
      michaelkenward
