marcos
Jul 24, 2014Novice
How set up security with XAVNB2001?
I've been using this system for about six months. Had a power failure, and when everything came back up the Netgear system would not work. Had to go through a factory reset and set up the whole thing again. It's now working, I can connect to it, but there is no security. I believe before the outage it was secured with WPA/WPA2 PSK.
Out of help from Netgear support, can't find the info in troubleshooting or setup.
TIA.
TIA.
1 Reply
- paulfrom34AspirantHow do you set-up security say WPA2 for homeplus system - I do not use Netgear router - at the moment the Netgear Ext operates unsecured.
Thanks
