Arismac
May 21, 2015Aspirant
How to connect to closest extender
Hi, i have setup without any problems the powerline XAVB5001 So i have one plug connected to router and another plug in another room. The problem is my devices, iphone and such, connect to the ...
michaelkenward
May 22, 2015Guru - Experienced User
If the first plug is near the router, and that is wifi, then just swap the plugs. You want the wifi extender farthest from the router. That is how I have my system set up.
