Arismac
May 21, 2015Aspirant
How to connect to closest extender
Hi, i have setup without any problems the powerline XAVB5001 So i have one plug connected to router and another plug in another room. The problem is my devices, iphone and such, connect to the ...
Arismac
May 22, 2015Aspirant
fordem wrote: Neither of the "plugs" in the XAVB5001 kit is "WiFi" capable - the kit contains a pair of identical powerline Ethernet adapters - you need to re-define the problem.
One IS wifi. Followed michaelkenward's suggestion, now everything works fine.
Wifi plug should not connect to the router but in the room you intend to have extra wifi signal in, that was my misunderstanding.
