Arismac
May 21, 2015Aspirant
How to connect to closest extender
Hi, i have setup without any problems the powerline XAVB5001 So i have one plug connected to router and another plug in another room. The problem is my devices, iphone and such, connect to the ...
michaelkenward
May 22, 2015Guru - Experienced User
Arismac wrote: Wifi plug should not connect to the router but in the room you intend to have extra wifi signal in, that was my misunderstanding.
The box that came with my kit is pretty clear on the issue.
"Connect the XAV5201 unit to your modem router."
"Connect the XWN5001 unit to an Ethernet-enabled device - such as an Internet-ready HDTV or set-top box - end other wireless devices through the WiFi access point."
In other words, don't connect the wifi bit to the router.
Manuals are often more confusing than the boxes.
Glad it worked ih the end.
