kepanorcal
Feb 14, 2017Aspirant
how to fix unsecured network message
I have the adapters setup and running. However, the unsecured network message pops up on the system tray icon. I setup the security option as directed in the manual but it still gives me the message...
- Feb 20, 2017
I've given up on this and moved on. Talked with Comcast and got an updated modem which changed the speeds dramatically. Funny how they expect the end user to complain to get results. Lesson here not related to the Powerline is to be the squeaky wheel! Peace and health
michaelkenward
Feb 15, 2017Guru - Experienced User
What Netgear hardware are we talking about here?
kepanorcal wrote:However, the unsecured network message pops up on the system tray icon.
Is that a Windows message or something from Norton? (It won't be from Netgear.)
Which security options? wifi? LAN?
kepanorcal wrote:
with the Windows Firewall turned off.
Why did you do that?
Oh, and XP? If you are worried about security you are using the wrong operating system. Microsoft's withdrawal of support means that it is now an open target for Internet hacks.
kepanorcal
Feb 15, 2017Aspirant
I'm using the PL1200 Powerline adapter.
The message is a Windows one.
The security option is the one available on the adapter via the Security button.
Windows Firewall is turned off thru recommendation of Norton Internet Security.
Yes I know I need to move on from XP.
I have an existing secured wifi network running as well.
How do the two coexist? Do I still use the existing wifi or the new Powerline network?
Modem is Arris TC862.
Thanks
- JamesGLFeb 16, 2017NETGEAR Employee Retired
Hi kepanorcal,
Please provide the screenshot of the error message.
- JamesGLFeb 19, 2017NETGEAR Employee Retired
Hi kepanorcal,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- kepanorcalFeb 20, 2017Aspirant
