xBaasic
Nov 17, 2015Aspirant
How to improve a powerline NetGear XAVB5221?
Hello, I recently bought a powerline NetGear XAVB5221. I have attached one of them in my room, and the other in my living room. (I live in a apertement, only 1 floor) If I connect the LAN cable fro...
xBaasic
Nov 19, 2015Aspirant
Hello, but can you tell me, how can i solve that problem, what i have to do to get better download speed with that powerline.
Please tell me.
Thank you.
TheEther
Nov 19, 2015Guru
First, I would first plug the Powerline adapters into the same or adjacent outlets to measure the maximum throughput.
Then read this older SmallNetBuilder article for some tips for improving performance. In a nutshell, it says to unplug devices that can disrupt the Powerline signal (the author mentioned that a plasma TV and cellphone charger were culprits in his house). Also, certain AFCI circuit breakers are really bad for Powerline.
Other than that, there may not be much else you can do other than move the Powerline adapters closer together. Experiment with different outlets, some may be electrically cleaner than others.
