dkbenost's avatar
dkbenost
How to install two adapters (PLW1000v2) to Powerline WIFI 1000
Hi. Is it possible to have 2 outputs (PLW1000v2) with the Powerline WIFI1000? Best Regards Bente
  • michaelkenward's avatar
    Mar 16, 2018
    That should work but you will not be able to buy a single PLW1000 plug. Like most powerline suppliers, Netgear sells them as bundles with two plugs. So you will end up with a spare "base" plug. You could use that for something else like a smart TV.
    Remember, when adding a plug to an existing powerline network, you need to follow this:
    >>> Adding a powerline adapter to an existing powerline network <<<
