ellieyork7
Apr 12, 2018Aspirant
I cannot get the Pick a Plug LED to light up
So, earlier today I tried to connect a new adapter to my current PLW1000 power line network. It was a Powerline 200 mini adapter that was HomePlugAV compatible. I rang Netgear helpline to see if it w...
ellieyork7
Apr 13, 2018Aspirant
I appreciate you taking the time to reply and send me the link for that guide but I’ve read it over about 10 times already!
I’ve basically tried to add another power line adapter to a current network, and now one of the adapters I originally had isn’t in the same network and I can’t get them to link back up because the pick a plug light won’t come on!
And I know it will slow the speed down, but thanks
I only have 100mbs max from our router anyways!
michaelkenward
Apr 13, 2018Guru - Experienced User
Like I said, it isn't clear to me what you have done. So forgive the repetition.
Reset both existing plugs and you should be able to set up the network from scratch. Do it with the two sitting next to each other to eliminate mains issues.
If that doens't work, something got bust.
