Shimmitar
Sep 20, 2015Aspirant
I can't get more than 10 MBPS from my netgear wifi extender.
The first time i set it up, i was getting 17mbps but now i'm getting barely ten. Anyone know how to fix this?
nhann
Sep 21, 2015NETGEAR Employee Retired
Hi Shimmitar,
Which router is connected to the extender? What speed do you receive on your router?
Which WiFi extender are you using? Are you setting it up as extender or access point?
