tosalet
Oct 19, 2015Aspirant
iPad fails to automatically change from router to Powerline wifi
I successfully installed Powerline XWNB5201 and XWNB5001 with extended wifi connection working properly with both iPad and Android phone. I then had to change the router and re-installed the Powerlin...
- Nov 02, 2015
Your solution worked, thank you. The process of doing a factory reset twice fixed it.
JamesGL
Oct 28, 2015NETGEAR Employee Retired
This might be an issue with the latest iOS update. To verify that one, you may try to connect to other wireless networks or hotspot and check if it will switch.
JamesGL
Community Team
tosalet
Nov 02, 2015Aspirant
