tosalet
Oct 19, 2015Aspirant
iPad fails to automatically change from router to Powerline wifi
I successfully installed Powerline XWNB5201 and XWNB5001 with extended wifi connection working properly with both iPad and Android phone. I then had to change the router and re-installed the Powerlin...
- Nov 02, 2015
Your solution worked, thank you. The process of doing a factory reset twice fixed it.
JamesGL
Oct 23, 2015NETGEAR Employee Retired
Hi tosalet,
Welcome to Community!
What is iOS version of your iPad? Have you updated it to the latest version? If yes, did you encounter the same scenario prior to updating to the latest iOS version?
JamesGL
Community Team
- tosaletOct 23, 2015Aspirant
Hi, thanks for responding so quickly. I have the latest IOS 9.1 and no, the problem did not occur on previous software. Having said that, I have changed my router recently and setup the Powerline to the new wifi.
- JamesGLOct 28, 2015NETGEAR Employee Retired
This might be an issue with the latest iOS update. To verify that one, you may try to connect to other wireless networks or hotspot and check if it will switch.
Regards,JamesGL
Community Team- tosaletNov 02, 2015Aspirant
